Anyone chip a 9000 series 4wd? Looking at chipping our 9300, chip will add about 20% so will be about 425 hp total. Since the motor is the same in the 93 and 9400 i think it would be able to handle it. Any inputs are appreciated. thanks
check if they have the same tranny and differentials.
cooling system might be different too, if there all the same, tune her up
I think the 9300 and 9400 drive trains are the same. BUT JD derates the 9400 different than a 9300 to protect the drive train. If I remember the 9400 doesn't reach full hp until 5th gear and up, not sure though. Chassis and engines are the same.
You should check with a JD dealer, they may run external lube circuit to rear axle like Case does on larger units.
