What all do you do before heading to the field. I have lubed all points and changed most of the filters. Checked over everything to make sure nothing is loose missing or broken. I just feel like I am missing something.
Does your machine have an incline auger in the tank, or the straight across transfer auger? If it has the incline, there is a double universal joint where the auger hooks up to the drive splines. They are a non-relubricable(sp) cross and cups. It is allways a good idea to check those every year.
Also on the unload auger, have you looked it over really good? Make sure the bevel gears are in good shape and not too much lash in them? How about the upper elbow gearcase? Did you grease it, and check the pins where the augers hook into it to make sure the cotter pins are good? I allways check the unload auger over a little extra. There's a bearing behind the big pulley that needs to be checked, and the bolts around the bottom of the vertical auger should all be checked for tightness. Otherwise the drive chain can skip teethe and when that happens, it can get nasty really quick.
Other than that, the alternator is about the only other trouble spot. Jon Hagen over on agtalk made a nifty little gadget that keeps his alternator clean and working the season long. It is made out of a couple eve trough elbows. Ask him about a pic of it.
Check and lube the hydro spline hub. Make sure the rollers on your torque sensor have no flat spots. Check the slip clutch hub behind the "big pulley" on your shoe shaft the holes get oblonged and then your shoe gets hammered at eache end of travel. Do you have a stone trap? If so check the hinge plate for wear. Check the bearings on your tailings delivery auger.
Give the leveler a quick check........
.....not good to have problems when you hit the field for real.....
.....to be serious for a moment.....have a real good look at the
rotor drive belt. If in doubt......change it. Yeah, I know, it's not
cheap. But fixing the mess that it will make if it breaks under load
will cost you a bunch more.
Where you been hiding 98j?
The old 8010 ready for another year or did it get updated?
And kingcotton another place to check on the 1480's is the upper bearings on the clean grain elevator, the chain drive side is hard to see but that's usually the one that goes out first.
