all conditions are different, but for one thing set your sensitivity to 25, that sound board is very sensitive. Confirm its actually wheat seed sieve loss. our settings run as follows for hard red spring wheat. small grain concave wedged in, rotors full rpm, 1330-1380 fan 810, pre-sieve if adjusted correctly with notch 1 is pretty much closed, we run notch 2. Top sieve .51 lower sieve .24-.20. Remember, if you are trying to clean white caps do it in the threshing not cleaning. also, the further open you run your sieves the more air you need
