How well do they work? Do they also test moisture content? Reliability? I have never heard of them. You also need a 20/20, which Gen? 1,2?
My quantium system is not working anymore. and software is non existing .
They work really well. Easy to install and use. On mine moisture is sensed from original Claas unit. May know of a used one for sale if you have any interest. It came off a 740.
model is 2013 740. it plugs into the can bus port by the return window in the cab. It actually doesn’t take the quantimeter out of play. That all remains intact and useable. It does require a 20/20 monitor in the cab and a different clean grain elevator chain. The mass flow replaces the top cap of clean grain elevator. The chain tensioner mechanism also still works the same. Really a clean install.
