1 - 12 of 12 Posts
Anybody bought one of those Magnum pressure washers from a ritchie bros sale or other auction? Are they chinese junk, can you get parts or are they just junk. Our old karcher one the pump quit on it so looking for a new one thinking hot water would be a nice feature but a hotsy or karcher are over $4000 can't justify that for the little bit we use it.
I've had one for two years, got a new pump from magnum, no issues. It wasn't the pumps fault.:redface: I've had some wiring issues, the ignition wire wasn't put on properly had to take the switch apart, and the machine kills the battery when running the burner, I haven't figured that one out yet. I'd guess I have 100hrs on it. Overall not a bad unit for the price. Mine is the magnum gold.
PUT OIL IN THE WATER PUMP BEFORE FIRING IT UP. Makes the unit about $500 cheaper. :redface:
I have had one for 3 - 4 yeas now
Had the temperature switch go when it was 6 months old called them they sent one on questions asked
That's been about the only problem so far
Should tell you we wash the dairy barns with it at least 1 time a year
As well as equipment
The new Karcher's are all "computerized" now. You probably wouldn't want it even if it was in your price range.
Karcher and Aladdin make good washers, I recommend getting a good big one, they are a lot of money but if you like clean equipment it's worth every penny, think I spent 6 grand on my Aladdin about 6-7 years ago, it now has 1300 hours on it, it's time to go through the burner on it because it's starting to smoke a bit but all I have invested so far is a few hoses, wands and fuel filters, about every 250 hours it needs that
I was kinda broke when I bought it, told the banker I had bought it so when she had to come get my equipment it would at least be clean, the look on her face was priceless
The one before that lasted 16 years before the coil started leaking and the pump was pretty well done for
We run to alkota hot water machines bought them used for around 1800 each. Had them for about 3 years with no problems probably get 200 to 300 hrs each
Got myself a 60gal gas hotwater heater on sale and use a Cat 310 SS pump with a 5hp electric in my well house. Get very hot water the first 15-20mins and gradually cools down on its own. The pump is almost 4gal/min and 2700psi. Great for washing grease and dirt off machinery just gotta be careful with the vechicals.
FWIW Mark
Mi-T-M is a good brand, made in Iowa and built with USA components and nothing in them is Chinese junk. They have commercial and also homeowner grade of units. I bought a used commercial unit a few years ago, not a single issue yet in many hundred hours of use, worn out several tip holders and tips, but nothing major. Nothing computerized and very simple to work on, they use general pumps and the burner is a basic unit pretty common anywhere and easy to get parts for, not really anything you need to go back to Mi-T-M for parts. Around here, the homeowner units John Deere sells, along with the cold water units they make.
Best Gas Pressure Washers
Do you need a mobile pressure washer that is easy to move around but also very powerful? Then a gas pressure washer may be the right choice for you.
We are going to be reviewing the best gas pressure washers that are available right now. These gas pressure washers benefit from having good mobility while offering an effective way to clean dirty surfaces such as sidewalks, driveways and walls. Check Out in Details Now! https://www.pressurecoach.com/best-gas-pressure-washers/
Best Commercial Pressure Washers
Household chores can often be time-consuming since just removing rubbish and dirt from your courtyard can sometimes take hours.
Commercial pressure washers offer a simple solution to this problem, as they allow you to remove all types of dirt effortlessly. Although pressure washers are commonly used in the industrial setting, a growing number of homeowners are using them to clean their households.
So, if you are thinking about getting a new commercial pressure washer, you’ve come to the right place. Check Out in Details Now! https://www.pressurecoach.com/best-commercial-pressure-washers/
Wall Mounted Pressure Washers
Do you often perform your pressure washing in the same place over and over? Then a wall mount pressure washer might be the ideal choice for you.
We’ll be reviewing the best wall mount pressure washers available. These pressure washers are easy to install in a mounting bracket permanently positioned in a reinforced wall. Check Out in Details Now! https://www.pressurecoach.com/best-wall-mount-pressure-washer
1 - 12 of 12 Posts
