1 - 2 of 2 Posts
Torn, We have a PRO 600 that we are going to use as our sprayer monitor on a new 2011 CASE SRX 1600 Sprayer. We are getting the ISOBUS cable with it. We are also putting the Raven Ultra-glide boom height on the sprayer. Can we run this Raven product thru the PRO 600 just as they do on the new Patriot sprayers ? Also, can we run the Raven Accu-Flo boom shutoff system thru the PRO 600 since we are also running guidance ? Am wondering what boom section switch controller we can hook up to this system. Don't want to have to use the touchscreen while bouncing down the field and try to hit the right spot on screen, switches are easier ! Any help would be appreciated.
The Raven system on the Patriot sprayers is CAN-based and not related to ISOBUS. The Pro 600 software is specifically made to talk to the Raven CAN nodes. On your PT sprayer, the sprayer is controlled via the ISOBUS standard. I doubt that you can run the proprietary CAN autoboom system through the Pro 600 while you're running the rest of the sprayer over ISOBUS, but you'd have to check with the AFS support guys to be sure.
To my knowledge there is no software for the Pro 600 to run an AccuFlo system. AccuBoom, yes, but not AccuFlo. And for AccuBoom you would have the same issue as noted above.
1 - 2 of 2 Posts
