anyone had problems with the pro-drive? I will repeat I love the pro-drive but have had 1 problem 4 times!
There is a coupler between the pump and motor (below the feeder house) that has stripped 4 times on me. They replaced all 4 parts twice(pump, motor, coupler and spacer block) happened on new parts as well.
Now they feel they had a bad batch of spacer blocks and got a new shipment in and discarded all old ones.............but if yours has not yet failed it still might.
this is a 2009, first happened with 120 hrs on machine. When it happens - you stop, in the field or road it doesn't' matter, you still STOP.
Dealership was fantastic about getting us going as was JD warranty.
If you have a newer machine with Pro-drive on it get this looked at now while machine is sitting. A simple spacer block is all you need to save a lot of head aches.
