I am a new CIH owner with a new 2588 and the transition from JD has been a trial. We got peas worked out by the time we were finished but canola is giving us headaches and the dealer can't seem to steer us in the right direction. Best so far is rotor 400, concave (small wire) 5.5(even with grate), wind 1000, chaffer front 1/8, middle 1/2, back 5/8, cleaning sieve 3/8. Wind has to be this high or we get more light trash than canola in hopper but we are losing over the sieve. We have tried Rotor 500 and tighter sieves and everything in between. In stall tests we find the outside two sections of the chaffer piled full and the center bare. At lower wind there is a bit sitting on the center sections but the sides are piled up about 6" deep and hopper full of trash. Today is a rain break and the dealer is coming out to replace the 4 separator bars with rasp bars. They believe we are getting too much material onto the sieves yet when I do the stall test it seems pretty even across and the auger pipes are sill visible. I thought there was some kind of blockage deflecting air away from the sides of the sieve but can't find anything except the fan throat does angle in about two inches on each side which would deflect some air inward. If anyone has experienced this please help or any other hints would be appreciated. Thanks
