Need some help with my case 970.....pto started slipping under load then quit altogether. So I pulled the pto clutches and had case dealer rebuild it, put it back together and that didn't cure it. pto shaft turns when engaged but I can stop it by hand. Clutch plates were worn and curved/blue from overheating so I was sure we had it. now thinking maybe its in the hyd vavle where the pto cable goes into, does anyone here know what the pressure is supposed to be?
Ok I did check the push/pull cable from the lever to the valve. But I guess now I have to pressure test the pump n the pto line after the valve.
