I had a mxu 135, I put a few fan clutches in it, but looks like you got a hold on that. While it is running at say 1350-1400 with hood open do you feel good airflow going by the engine? Maybe it is more do for a cleaning than you realize, maybe take the inter cooler off and give everything a good cleaning. It seemed like mine ran warmer than it should, I would kill a fan motor on my 1750 JD planter pretty consistently at 1500 acres, seemed to be that it needed a fan clutch every time. Make sure if you have a external flow control that it is on the return side, always remember when in dought, meter out.
