Is there a trick to disassemble the feederhouse top variable speed drive pulley and cylinder?
L leonardfarms · Registered Joined Mar 22, 2015 · 1 Posts Discussion Starter · #1 · Mar 22, 2015 Only show this user Is there a trick to disassemble the feederhouse top variable speed drive pulley and cylinder?
madcow · Registered Joined Dec 14, 2010 · 849 Posts #2 · Mar 22, 2015 Only show this user run feeder house to slow speed then loosen the belts and hydraulic hose. remove the bolts that hold plate 15 on. then you are going to need a strong 1/2" breaker bar to remove 21. everything up to and after that point is pretty self explanatory. John Deere - Parts Catalog
