1 - 2 of 2 Posts
If it is an old delco remy, the main power output wire should have a small jumper to the #2 terminal on the regulator. (should be a spade connector). If in doubt there should be lots of diagrams out there for the older delcos.
The #1 would be the exciter wire likely hooked up to an alt lite in the cab off the ignition.
If it isn't a delco disreguard this, there should be some info or diagrams on the net if you just do a search if you havent already...
1 - 2 of 2 Posts
