1 - 1 of 1 Posts
Why is it F2 bards that are installed on the bottom of the rotor cage? Are they flat rather than a curved bar? Should it be a forward or reverse bar? Also the previous owner of the machine told me the engine output shaft should have a new bearing installed every second year, and this is the year. If not done likely to end up with a bad shaft. Is this recommended, or generally done? thanks mark
1 - 1 of 1 Posts
