Anyone know how to adjust the cab lever so that it goes all the way forward into the max rpm slot? Had to adjust my idle after some idiot cranked it up to 2600rpm and now it tends to slide back slowly whenever I have it running wide open. Always appreciate the help.
You should be able to adjust the cable jam nuts where it mounts to bracket on engine. Also I believe the clevis on the end of cable is threaded also. Lengthen or shorten as needed.
