2012 760tt...
1. The two speed power rear axle, shut it off for road transport, how about in the field high or low? Is there some kinda basic speed guide lines?
2. Going to install cb radio where is the best location? I see the knockout to the right of the radio, with power I assume and a fm radio antenna it looks like? Seed cleaner I read an old thread of yours on it, did anything ever come of it? Otherwise I'm going right/behind the seat, and run my own cable and steal power from 12v outlets there.
3. Is there any cold weather kits? I have the block heater, but any ether/starting fluid or glow plugs?
4. Pulled it out of storage the other day to move it to the shop to go through it. Started it up and got a warning something about brakes pressure test time exceeded? Would only move about 0.1 mph. Looked in operator Manuel and it said apply brakes firmly and also went into how to test the system. Restarted it apply brakes, got nothing... Call butler service department the guy was completely lost and just offer to send a truck up (on my dime)...I then Restarted again and hammered the brakes to the floor and it beep...I cleared the code and it worked fine. Is this normal? How often does it happen book made it sound like ever 20 hours, is it going to just slow down like that ever 20 hours no matter what?
Note: I have browsed/read the Manuels and went back and looked for these answers in the books. With no help, not that there not in there but I did see it.
Thanks
Thanks
