Re: 1660 Clean Grain Chain
Check that the chain is routed properly on top. We had a 1440 once and the chain got put on wrong and the pull of the chain went over the idler gear instead directly down to the drive gear. So it would flex under load sometimes and jump off. Once we put it on properly it worked fine. If the elevator is too full, there is a slip clutch that protects the system.
