Re: 35ft 2020
We have two 8010's with the 35' 2020 heads on them and have had very little problems with them. What are you going to be cutting with it? How well is it yielding? How fast are you going? What kind of terrain do you have in the fields? I am not 100% sure, but I think a 2020 will out flex a flex draper.
Re: 35ft 2020
if you can afford a macdon draper then you need to get it over the 2020....
Our local dealer has sold several 2020's and has had good luck with them... so i won't be afraid of it at all... u will just get more done with a flex...
good luck
Re: 35ft 2020
drapers are just nicer to run. easier to set and do a better job. 2020 will be gone this fall. new flex header comng
Re: 35ft 2020
I would not recommend the 2020 over a 2162. You will lose capacity in the wheat for sure. The draper flex has more flex, 10" compared to 6" with the 2020. If you do get one make sure u put a air reel on it. It is the only way to make it feed nice in pulse crops.
