1 - 10 of 10 Posts
I have heard the clean grain elevator paddles are coming off a few of the 70 series (heard 9770sts in particular).
Also you may put up your bin extensions to make sure they fit right, the front left corner seems to not want to fit on about 1/2 of them.
yes you will hate the 1965 rotory dial it is a joke!!!!!!!! i haven't seen any body in our part that liked that sh--t yet and it is also going to get some insurances jobs out of it because you have to look down to see what you are trying to adjust and then. what the h--ll is up with autosteer resume in the 123 buttons for that needs to be put in a sep. switch so you can use 123 for header hight and then auto in other. if you cut endrows and then set ab line to other end of field and when you get there start your endrows there and use 123 for header hight then you will turn on the ab line you just set. not good!!!!!if you are near woods take out a snoot or 2!!!hahaha need fixing this!!! so whatch out!!!
Out of 12 new machines, half of them the A/c was overcharged and it wouldn't work
one machine had a fuel system sensor issue and wouldn't run right half of the time
other than that i wish that the machines command center was a GS2 monitor-larger with a touch screen. The machine is sweet and does a nice job
1 - 10 of 10 Posts
