1 - 1 of 1 Posts
Re: 9560walker vs. 9750sts
The difference in header sizes is much closer to 28%. Both combines will probably operate at similar ground speeds. However, when it starts getting tough out or there are green stems, the STS will become more sensitive to the tougher conditions than the conventional combine will, and may at times need to slow down more so than the 9560. Otherwise, the 9760 should have a 25-30% advantage over the 9560 in ideal conditions.
1 - 1 of 1 Posts
