Re: 9600 unload auger
Have someone in the cab hit the switch to swing the auger out while you check the auger swing valve solenoids and dump valve for magnetism. The chart for which solenoid to check is on the inside of the combine sidesheet or if you need a list let me know.
jd
jd
