Re: bottom tank unloading auger
Hi Plowmaster!
Try to straight it out and then give it a twirl (with no load on it!) If you think it vibrates too much and you can't make it better, you'll probably have to get a new or used one in there.
Vibrations are no good for bearings and so on, but again it depends on the speed it's running with... A little vibration shouldn't do all that much - will be dampened once you put some grain trough it.
Just remember for every time you bend it, you make the steel weaker...
Discussion Starter · #2 ·
Hmmmm......
If it's that much of a mess, don't you think it's good idea just to buy another one?
If you do, chances of breaking down again are smaller as well...
