1 - 18 of 18 Posts
Re: capacity of 9400 combine in corn ??
what combiness said, 5mph is too fast unless you don't care what your field looks like.
We're running a one year old 693 platform and it does a great job at 3.9mph, we go 4.5mph and it doesn't cuz the stalks up near as good.
Quote:what combiness said, 5mph is too fast unless you don't care what your field looks like.
How would that have an Effect on what your paddock looks like? I havn't had much time with corn.
maybe language barrier difference, but whats a paddock?
a quick search on google said it was a field, so im just gonna give my explanation based on that...
If ya go fast, it doesn't give the knife rolls enough time to chew the stalks of the corn, and you'll end up with 3'-4' tall stalks int he field because instead of chewing the stalks into tiny 3"-4" stalks, it just strips the ear and leaves the stalk almost completely intact.
When you go to chisel the field, its harder because the stalks want to roll up with each other and pile up in front of the chisel shanks. which is a pain to clean out, and doesn't save you anytime at all. Also, the faster you go, the more grain loss you have....technology has advanced alot, but engineers still can't make a perfect cornhead/combine that allowed you to go 5mph with nice short stalk stubble and almost zero grain loss.
I'll snap some pics today if we get the combine running again of what 5mph cornstalks look like and whats dropped out of the back of the combine for seed compared to 4mph. You lose alot of money quickly going too fast...its really uncalled for unless your on the last field of the year and trying to beat a week long storm that would be coming in.
we tried 4.5mph and it was too much, but we run 4.2mph and it still does a great job...i'd just play around with it and see what you like is my best advice....we like our stalks short so it makes easier work covering them up with the ripper.
LOL.
I really should stop saying paddock.
That makes sense. And if you can get those pictures I would be very appreciative. considering it puts those marks in your feild.
I agree with cartguy. My 9400 with a 494 head is about at its horsepower and strawwalker limit at 4 mph in 200 bu. corn. Unless you've turned the 'smoke screw' and have grain pouring over the walkers, I don't think a 9400 with an 8 row head is a real good idea, at least in my conditions.
Adrian
We run a 9600 with a 8 row at around 4.5-4.7 in 170-210 bpa corn and have very little loss but we only try to get ears off the stalk instead of trying to run the whole stalk through the machine. We burn our fields off when through, so stalk height doesn't really matter because it only leaves about a three inch stalk, so we can speed up a little without any loss.
Discussion Starter · #12 ·
If your corn head is set right, and corn has no weird stalk problems, there is really no sound reason to ever run the entire plant through the combine--just the ears. Corn heads are designed to snap or pop off those ears, and that's what the machine eats.
Still, by what you say and ground speeds given for the 9600, what I said earlier, for the 9400 is reasonably accurate.
Type of corn, stalk condition, moisture, row length, bin capacity, auger cart and truck operator skill are all variables and there are more I can't list off the top of my head.
I can't shell over 2000 bu/hr here, no one can handle that much
A few yrs back, shelled some 220 corn at4.5-4.8 , at 13%, easy shelling, very low MOG intake, 1/2 mile rows and a cart with 2 semis hauling to town and had elevator in town dumping in a separate pit and the leg rate at 3000 bph couldn't keep up so we had to back off a tad.
Depending on conditions, a 9400 and 8 row will be way low on power and even worse on bin capacity.
jd
Man we're really railing on the ol' 94's in this post - lest we forget it has the same size throat, cylinder/concave, shoe size, and hydraulics as a 95xx, just shorter walkers, less hp and a tiny bin. There are plenty of 95xx with an 8 row header out there.
It will handle an 8 row, just will be a big pain in the kisser.
jd
1 - 18 of 18 Posts
