Re: Case IH 1680
Only thing is to unload at full throttle. Even then it will probably seem slow. Also, check the slats that cover the augers in the grain tank, make sure they're all the way up. A tip: when unloading at full power gently engage the unloader drive. Earlier 1680s had a shear bolt protecting the unloader drive and it will break every time if you just haul off and yank on that lever.
