Re: Code 44E on 9600 Combine
I believe it's your intercooler is plugged, and it's cutting your hp back to keep the air cooler
44E is an error on the engine speed sensor in the pump, make sure all your connectors at the plug to the pump are clean and that the ground points back by the batteries are clean and tight.
jd
Thats a avery interesting issue. does it occur reguarly? or is it known to occur reguarly on that model of Headers?
