Re: hid light kit 2388
We have converted all six of our lights in the roof on our 2188 to HIDs. The only kit that I could find that will retrofit was the inside set that are the hi/lows. The other 4 will take some modification to make them work. I took the bulb holder out of the lens and took a 9004 single beam bulb and ground down the base to the right diameter. Once it is ground down enough to slide all the way down to the lip on the housing I just put a bead of silicone around it to hold it in place. We have the outside 2 @ 35W the middle 2 @ 55W and the inside 2 @ 35W hi/low.
It seems that the majority of the HID kits are made in China and most ballasts come from there. Our kits that we sell are all from China. We have had better luck with the regular ballasts then the slim ballasts.
By the way the light output is amazing almost like working in daylight. We also put a 35W at the end of our auger and a 35W at the back so there's no shortage of light on the combine.
This also got rid of the connection problems that we had with our roof lights
