Re: pickup/reel belt on 9760
You need to take the hose off at the upper feederhouse variable sheaves and i believe it easiest at the multicoupler as there is no swivel at piston and the sheild above the hoses comes off with one bolt and sliding sheild either up or down---------as far as no hoses needing to be removed it may be referring to hoses at reel pummp drive on same belt drive
