Re: Welding the top sieve???
ive seen farmers do it. i wouldnt see why it would matter if you have fixed all of the moving parts that carry the seives. i think if you were to just weld it and not fix it right it would just cause bigger problems later.
Did you check the play between the pitman arms and the hex shaft? I found about .060" play in ours and took an old set of feeler gauges and made shims out of them. I shimmed 3 sides of the hex shaft and took all the slop out between it and the pitman arms. That not only made it run a little smoother, but seemed to make it a little quieter too.
Before I found the bad bushings and the play between the arms and the shaft I broke the top sieve too. I welded it up and fish plated it with 1/4" flat bar but it broke right away. Once you've got the real problem fixed, a welded top sieve might work and I'd sure give it a shot before I plunked down the green to buy a new one.
