Re: Yeehoooo! New Gleaners R6 and A6 are out!!!!
Aug 13, 2008, 7:47am, gleanerf2fan wrote:New features on the new R6: (Want to see the new features of the A6. Look at the MF section at the new Axial series.)
--Newly designed mud shields are removable with pins.
--Cascade pan for improved performance in high moisture corn and milo.
--Optional electronic chaffer and sieve adjustment.
--12” (305 mm) cross auger for unmatched average unloading rate of 4.0 bu. per second.
--12” (305 mm) bin fill auger for increased clean grain handling capacity.
--3’ longer unloader tube for increased reach and 19” greater discharge height.
--Upgraded cab interior and field lighting package.
--Optional leather heated seat (cloth seat standard).
The list in the quote is from the pages 12 and 13 in the R6 brochure (page 7 in the PDF posted on
www.agcoiron.com).
The A6 Series brochure is the same. The what's new highlights are on pages 12 and 13 (page 7 of the PDF posted on
www.agcoiron.com). Here's the A6 list.
--New grain handling system on A66 (Class VI) and A76 (Class VII) features Direct Flow™ unloading system. Utilizing only two augers, versus three on competitive models, reduces power requirement when unloading, machinery wear and cracking of grain.
--New 12” (305 mm) bin fill auger for increased grain handling capacity on all models.
--New optional 350 bushel (12,334 L) grain bin on A76 Model.
--New cab with ISOBUS electronics and virtual terminal with programmability up to 20 different crop settings can be stored.
--Automatic one-button recall of all crop setting functions.
--Reduced B pillar for improved visibility.
--New armrest controls with integrated command arm mounted C2000 virtual terminal with optional video capability.
--New handsome styling on A66, A76 and A86 models.
--New cab roof lighting package for unmatched night vision.
--New service lights for engine compartment, left and right side of combine.
--Easier servicing with integrated grease banks.
--New heavy duty adjustable axle and rear wheel assist (RWA) option on A76 with larger steering tire options available.
Moving the faster unloading rate available previously only on the Class VIII Gleaner into all five models in the line up appears to be one of the big items for the 2009 Gleaners.
