I am interested in seeing if anyone has been able to successfully read OPI cables with an Arduino or other microcontroller. I found an old thread about it, and it looks like folks have been able to get the temperature and relative humidity.
www.thecombineforum.com
The main question I have here is how can you get the addresses of the different sensors, and how do you know which level in the cable they are?
Thank you for your ideas. The subscriptions on these cables are just getting very high.
Reading Opi moisture cables with 1wire (one wire)
If you use a resistance sensor, and calibrate it for the density of the grain, you can get far better moisture readings than the sensors in OPI cables. I just read a PhD thesis done a couple of years ago on using small capacitive sensors to measure moisture. They had success, though they never...
