2011 with 1050 engine hours, about 670 effective operating hours. The right main countershaft bearing is done for. No fire and I don't think the shaft was harmed. I took the pulleys off last night. I need to torch the bearing off the shaft. I have noticed the zerk not wanting to take grease lately. The bearing appeared completely dry. I have been using amsoil polymeric but maybe should rethink thst. Found a rotor bearing out when doing rotor flow kit.
It all came apart well for the small amount if tools I had to work with...but,
How do I inspect shaft for cracks?
what caused bearing failure?
how do I get taper rings tight for the two pulleys?
Any other advice.
Thanks
Any other advice.
Thanks
