My TR86 would go 4.6 MPH in second gear. My TR99 goes 3.8 MPH. My TR86 would go 8.6 MPH in third gear. My TR99 goes 6.9 MPH. My TR86 would go 20 MPH in fourth gear. My TR99 goes 15 MPH. Why are the bigger machines so much slower? Other brands of combines have a higher road speed. Is there anything that can be done to increase the speeds on this combine?
My TR 86 matched the speeds listed in the manual. My TR 99 matches the speeds listed in the manual. It has the proper calibration settings for my tires. The speeds are right and match up with my CIH MX 240 with radar controlled speed indicator. I have talked to others and it just seems that the larger machine is made to operate slower in all gears. I just don't understand why since other companies operate their bigger machines faster.
· Super Moderator
The easiest and most accurate way to check speed these days is a hand held GPS receiver.
I've checked all my speedometers and odometers on all my vehicles/equipment.
Sometimes you get a surprise like a 97 ford pick-up that reads 8% fast.
Don
· Premium Member
The CRs do 21 or 22. Our TR98 does 15.4. An old TR85 we had did 21. The 98's high idle is 2250, the 85's was 2800. Probably makes a pretty large difference since they were 1st designed with 3208s and then the other engines were put in afterwards. Not sure where they would have changed pulley sizes -on the engine and I'm back to square one. On the thresher clutch and it makes sense.
I bet your 99 goes way faster working in the field though.
