Put a rodono chopper in last fall no troubles this summer put on the speed up hub and pulley on and can't keep the u joint together (s77) the key way on the accelerator shaft is egged out now after three u joints failing any one else have issues thinking of going back to the original hub and pulley
Tim
Fitted both and did 200 hours last harvest with no trouble. Does it vibrate? Make sure the pulley was balanced and is aligned correctly may be.
Once the shaft is compromised you will need loctite or better surface to get it to hold. We have in per delivery to torque the clamp bolts and never problem afterthat
