Just changed the Straw Chopper rotor assembly on the R60, and the shaft, magnetic hub get major hot when running. 2 questions:
Is the chopper supposed to run all the time, even when the mill is off?
Should there be clearance between the magnetic hub and the clutch plate when it not engaged?
Any ideas why these parts are heating up? Rotor, hammers, and bearings are all new!
