Was wondering about how much the rotor belt should be slipping under load. I've been having troubles with it slipping when I get the combine a little too loaded up. Its caused me to plug the rotor twice and smoke the belt both times. Right now I have the rotor set at 1000rpm unloaded and when its under load it's running around 890-900rpm. Is a 100rpm drop too much? There are times when im really trying to push things that it drops down to around 850-870rpm as well. I've checked to make sure that all the belts are tight and that the pulleys are in good shape. Is there anything else that I need to look at?
Sorry, this is on a 2188 if that matters?
