1 - 2 of 2 Posts
WE have to replace the seal in the right hand rotor gearbox. The dealer said it is the seal inside of combine and was caused by a cornstalk or something. How big of a job is this to replace. The dealer said it was a winter project. The combine is our TR98. It has 2500 hours on it. I was wondering if I have to tear the rotors out, what other work should be done? What about these aftermarket rotors or rasp bars? Should one replace with stock New Holland items? Three days in wheat harvest the gearbox oil was to the add line. The dealer said that when they get bad he even puts a couple of tubes of grease in them to keep going. They are going to replace the whole Bubbleup auger in our TR99 next week. We also found the hydralic tank for the reel and chaff spreader is leaking around the gussets. I thought I could just replace the tank, but it costs 800.00 bucks. They have been bring them to a machine shop and fabricating a fix of some kind. It sounds like this happens quite a bit on the TR99's. This is our first tank that has had a problem, I wonder if they are using cheaper steel or something.
Really liked the TR99 though, compared to the TR98 it did a much better job iin the wheat and seemed quieter. I could be imaging this though, should be the same cab. The guy that had the 99 said his TR98 did not do a good job in wheat either. Our Tr97 also did a good job in wheat. Maybe the factory settings weren't as good as the other combines.
Tr
The box has to come out as the seal is under the sprocket, that is part of the output shaft. It is a fairly major job but should be done. Run the risk of burning out the gearbox.
1 - 2 of 2 Posts
