Hi.
I just bought an 1991 Axial Flow 1680 E with 20 foot 1030 Header.
It had a stone damidge and I decided to put a new rotor in it.
It has a front, wich in Denmark is called ``exeller-kit`` and is supposed to increase the capacity extentional.
Does anyone have any experience with that overthere or downunder ? I do barley, wheat and rape.
It will replace an old 1460 AF so I hope I will have a much better capacity and comfort.
Thanks
We put this http://www.stewartsteel.com/ag/acceler.html
on the 1680 (30' Macdon)last season and it made a big difference. More suction and fed a lot better. I don’t drive this one but the operator said it was a lot better and gained some ground speed. We also put this http://www.stewartsteel.com/ag/extender.html model EXT-CIH-FT3 on the 2188 which I operate
. It really helped for easier unloading with the 36’ Macdon header with out hitting the truck.
Which cleaning fan does your combine have? If it doesn’t have the newer squirrel cage fan I would recommend putting it on. There are a few more upgrades that we put on the 1680 also but can’t remember
all of them. Good luck with your 1680 being they are a good combine!
Hi every one.
Thanks for your inputs. Cleaning fan is the standard one.
I am going to put a sideknive on the right side of the header in order to straight combine rape(canola) this season.We have usually a heavy irrigated crop with some green material in it, looking forward to putting it to work
