I need to install the monitor for a Shelbourne head in my S77. I have not found anywhere to run the cable to get into the cab. Does anyone know if there is a place to run a cable into the cab from outside?
Thanks,
Gary
I have an R65, but i've run my cables along the bottom of the RH door, ive never had a problem with the cab not sealing.
Ken Adams
If you want something more permanent, there is a area - right hand side floor where they are now running cables. There is room for a few extra holes and cables to be run through. Fairly easy to access through right hand door under floor mat and if I remember correctly there is a panel that removes easily.
I drilled a couple holes in the right hand floor next to the power cable for camera cables and gps cables then ran up the back of the plastic and came out the existing hole about 18 inches from the floor. Worked great and still looks pretty clean
