Ruputured hydro steel line
887 Views 1 Reply 2 Participants Last post by  grass
The steel hydro line that goes to the ground drive hydro motor on a 1660 ruptured at the tube seam. ( Fast way to lose oil) The mig welder put it together again. Any idea as to the cause? The line is secure with brackets padded and tight.
1 - 2 of 2 Posts
sounds like vibrations not the problem if brackets are tight and cushioned. They do wear internally over time, especially on seams , welds and corners. System pressure also makes a difference. Just my .02 worth anyway.
1 - 2 of 2 Posts
