Have an R52 and after a period of 10 minutes to 30 minutes the RWA fuse will blow. Tried a bigger fuse and same result. Is the coil or the solenoid the problem? or maybe in the RWA valve assembly itself? The single wire to the solenoid checks out ok.
The cylinder speed and reel lift circuits on the same fuse work fine when the RWA is off so I know its isolated to the RWA circuit. Thanks
