I wish to pose a question regarding combine settings for rye and/or barley. To begin with, we have a 2366 w/ specialty rotor and Kile Rotor flights (a welcome improvement).
I should point out that we are swathing the whole plant, so there is a lot of material to put through the machine.
Our problem is that we seem to have trouble with unthrashed partial or whole heads in the grain sample. Our typical settings include: Rotor=920; Fan = 920; shoe is closed; chaffer = 1/2 in (or less). We have the LW concaves with clearance set fairly wide - 8.2 (indicator setting) to accommodate the large volume of straw and to achieve grain on grain thrashing. The wider concave setting also seems to lessen the straw grinding. We also have filler plates installed in the first two sections of the concave.
Besides the unthrashed heads in the grain tank, due to rotor thumping and, perhaps, lack of power, our field speed are limited to <1 - 2.5 mph, which seems very slow. We only have a 12' swath! The machine appears do a good job at removing the grain from the windrow when looking behind the combine.
Where are we going wrong? Can we improve our throughput, lessen the power/fuel requirements, and clean up our sample?
