Most likely buildup of 'sap' from corn stalks that make rollers on shifter rods not roll smoothly in the cams that are operated from the cable. 04' 75 happens every year. can clean up with water or scrape out cams with some sort of screwdriver. Don't use any lube it will only make a bad situation worse. Once it breaks loose will work for quite a while again. good luck
