i was needing some help on how to get the trough out that is under the four conveyor augers . We got all the conveyor augers out and have not figured out how to get the pan out. The part number for it is ah218425
I've never done an S but if its the same as a 60/70 then it goes in from the back. Judging by the part # the pan is the same as a 70 as well. Make sure you have all the bolts out. There's a few hiding in funny corners.
Yeah I'm sure it's the same. So you didn't have to remove the fan in order to get the pan out. We were having trouble getting to bolts that are toward the front of the machine
You need to be a contortionist and crawl in on top of the transmission to get all the front bolts. A real PITA. There are a couple other bolts above the pan in the side walls that need to come out for clearance. With the concaves out it will come out the left side.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
