These disrupters are part of a rice enhancment package we used but they work well in all crops and really help with rotor loss without robbing H.P. and they are JD Parts so nothing needs to be modified. The disrupters have been available since the S-series came out. We use them in all crops including 30-60 Bu. winter wheat which we harvest in May, sorgham, corn, rice, and soybeans.When we first started using them everyone was concerned about overloading the cleaning shoe and trashy sample. We haven't had an issue with either. The disrupters will only work with the Corn Cob Mix separator grates.
Disrupters Part Number HXE38180. You unbolt the 1st and 3rd row on the right hand side of the separator grates and bolt these in. We use 8 and that seems to work real well but if you find a better combination let me know. It's easier to put the disrupters in with the grates on the ground. On S680 & S690s it can be a pain to get in behind the rethesher. I usually take the belt that drives the retheshing system off and take the idler pulley and arm off also. There is room to get in behind the thing after that.
One thing that is nice about the corn cob mix grates is they fit everything from a 9660 STS to a S690. So they are also very versatile. We have bought one set and used them on 3 different machines. We just pull the original grates out and put them in the barn and put the CCMs in. Trade or sell a machine just pull the CCMs out and put the originals back in. Hope this helps because it sure made a believer out of me.
