So we have a 2011 S77 and running a 36ft honybee front, we have had the front for 6 - 7 years. Going on what NDDan has been pointing out about fixing the feed in general on different fronts, i took some measurements and this is what i propose to do, wondering if i am on the right track or if there is other things to also consider.
To stop material from getting wrapped over the end of the slats, it looks like the opening needs to be around 800mm or 2.6 ft, which is measuring from center of each outside chain. Currently the opening is the full width of the feeder, which potentially means material can wrap around the ends of slats and repeat back around and cause slugs in the feeder. Am i reading this correct?
Experience has shown it works fine untill pushed or when conditions toughen than it will plug.
Remove 2 retractable fingers either end of feed auger because effectively they are pushing material back into gap between end of slats and feeder wall.
When i narrow down opening they would then be attempting to push material into blanked off spaces.
Also unbolt guides on the trough under the table auger and move them in to 800mm or 2.6 ft, and add material to fill in voids left.
Do i need to lift and hold the table auger up to its highest level or let it float?
Also do i need to add flighting to table auger towards the center of the auger?
Would it improve things to actually narrow the drapers down to the same width i am intending to make the opening, so 800mm or 2.6ft?
Thanks in advance for any feed back, would be much appreciated.
