Have a 2012 S77 combine here throwing error code: 521008/ 1
SCR system error: DEF pressure build up failure.
Agco has suggested it could be the DEF pump or the head unit on the DEF tank itself. Tried switching pumps between our two combines and error code still trips so we think the pump is ok.
Have a new control/ head unit that goes on top of and into the def tank to install and try next. Guess the tube that holds def can crack due to freezing, thus causing air leak and pressure problems.
Tried removing the old one and find it is quite hard to turn and get out of tank. Seems like we can only turn the head unit an 1/8 th of a turn or less counter clockwise, then try to pull up. Lots of resistance pulling it up and don't want to wreck the tank.
Anyone else removed one of these before? Should be an easy swap but I don't want to wreck something else in the process.
Cheers,
Steve
Cheers,
Steve
