I just bought a 2013 S77. The feeder plugs far too easily in my opinion. I have all the blocks set for grain and I am running it on the high speed setting. I also have the front drum set out as far as it will go to get it to pull material out of the header more aggressively. The problem seems to be at the transition point between the front and rear chains. When it plugs there will be a wad on top of the front chains right under the rear inspection plate. Anyone else run into this and what did you do to help it?
