I need to hook up the monitor for a shelbourne header, and I have to have it turn on and off by the ignition switch. It needs to be at least a 15 amp fuse. The dealer hooked up my 2-way radio to the cigarette lighter, so I cannot use it. The fuse panel shows a spare 15 amp fuse, but I cannot find the wire from it.
Thank you,
Gary
Ken Adams
Gary L - if you do NOT have rear wheel assist and are mounting your monitor on side of console, you could use the power at rwa switch plug that is located just below where rwa switch would have been - accessable by removing cover on right side of console. This is a 15 amp circuit, but is also with back-up lights.
