Anyone found anything better then the factory ratchet lever for the concave adjustment? Mine has always been very hard to flip the direction lever on, works better for a little while if you blow it out and lube it up good, but it never works decent for very long. A new one is $143.00, which I...
I need advice for a new combine (no hill only flat land).. actually have a 2388.
Are the bushing in the midrange 140 serie combine with the new Xflow cleaning system really beefed up ?
Is the Xflow cleaning system reliable or it's better to stay with the old fashionned cleaning system with...
G’day all after some settings for haversting windrowed canola. Crop yield is around 2.5T to the ha. With reasonable grain weight. Current settings are. Concaves large, small, slot, slot. Rotor speed 580. Fan speed 650, pre sieve 2, upper 10 lower 8. Can’t seem to get the capacity out of the...
Had our 8240 for 5 seasons now and have had our fair share of issues with the thing. Wanted to get an idea from others if we're an outlier or if this is standard with Case combines? We ran CRs previously.
2200 engine 1600 rotor
Overheating hydro issues first season
Feeder house drive shaft bad...
what potentiometer part number is correct for a older 1020 header on a 2166. We were sent a 127360A2. Its not working. The prev owner said the combine was working with his header. Our header was working correct on a 1440, but we were told we needed a different potentiometer for the 2166. someone...
