Trying to pull apart the knife drive/wobble box can anyone point me to an exploded view to show me what i will find besides a stuffed bearing. can the bearings be replaced or is it cheaper to get a new one. I'm having a fair bit of difficulty getting the flywheel? off the top. maybe i'm going in from the wrong end???
If you go onto the New Holland website and then into the parts and look up a 994 or 94C header, it should be there. It is diagram number 4.40 in the 94C. That might help. I've never had one apart, but might give you a start.
I haven't had one apart ,there are very few parts inside ,bearings are not too expensive ,if you need a crown wheel and pinion and a rotor you can shoot $1000 fast a new drive is $3000 or more.
