So my question is specific to seed Hawks. I have a 50 foot seedhawk with 500 tow behind cart with one fan and mechanical meters, both are 2008. My tractor is a nh t9.450 with standard Hyd pump 45 Gpm. Four hyd circuits.
My tool bar has the small rubber option on the rear so going to a bigger cart isn't an option, so I am considering getting a second tow between seed hawk cart, I have a line on a used one with twin fans and hyd meters.
Question. Do the two fans on the newer cart run off of one hyd circuit? If so can I disconect the second fan ( I won't need it) and plump in the hyd lines to the fan on my older cart that is tow behind, and then run the fans on both carts on one circuit. If not will my tractor have the hyd flow to run one fan on each cart using its own hyd circuit
I just wanna be sure this is doable without upgrading my tractor
